hi i was at a drag racing event today in cumbria with my 323i, i was running consistant 15s best been 15.47 but i just need that exstra little bit dose any one have any ideas with engine tuning n what the best way of doing it what kinda bhp can i get out of one of the 323 (im a machanic so im quite handy) with this been my first bmw i dnt no many trics with them, any advice would be helpfull
thanks
Is it manual or auto?
I drag race my Camaro. Going up that same track for hours on end trying to beat my times.
Now ill be honest, iv never drag raced my bmw, but just by adding a Higher ratio rear axle will help you get off the line quicker and get you into the power band faster.. But this is only really good for the 1/4 mile. Normal driving you'll find your top speed is reduced.
Id suggest maybe one from an M3...
If its auto compliment that axle by considering a stall converter of some sort. If its manual convert it to auto. Trust me when i say autos are better than manuals for drag racing!
A stall is when the torque converter locks up under load and you can change this with a stall converter.
Most cars have anywhere from 1,000 to 1,400rpm stalls from the factory. The reason a stall converter works is simple.. an engine at 1,200rpm is only making about 80 or so horsepower (on average), but at 3,500rpm it could be making 150 to 200hp, and obviously trying to get a car moving using 150-200hp is going to be much easier than one trying to launch at 80hp or so. Most engines don't make power until 3,000 or so rpm, hence why when you have a higher horsepower engine with a big cam, you need a higher stall speed so the engine is closer to it's "power band" when taking-off from the line, otherwise it will be a !Removed! off the line.
Just remember.. 80% of the race is the first 100 feet. If you can't get off the line, you are going to lose the race.
Sorry mate, i missed you saying your a mechanic so you probably already know everything i just wrote..
But i could talk and talk about drag racing =p And as im sure u found out its soo addictive!
Stainless steel race decat exhaust,air induction kit,BBTB and inlet manifold upgrade followed by a remap :) job done :)
Now thats saying something ian =p iv noticed your extensive knowledge throughout the forum!
      Tyres for front of my 240i
      520d advice
    4. 13
      Fuel rail pressure problems.
    5. 2
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
