HI,i really hope someone can help me,ive gone to pull bonnet lever to release bonnet but bonnet isnt releasing ,ive taken off kidney grills to get a better look.Ive had help from Dabsy on how to release the n/s catch which has helped loads i think the cable has gone from the lever to the catch on the drivers side how can i get around this to get it to pop?
Use the same method for other side.
ive cut away the plastic cowl to revel the drivers side catch ,is there a lever or something on the back of the catch to pull or push to release the bonnet?
when you pull the bonnet lever can you see the cable attached to it?or in other words do you think the cable has stretched or snapped?
can you get some pliers in there and give it a right good pull whilst someone else wiggles the bonnet?
yes mate.get the pliers on it and yank the hell out of it.haha.it should open then surely?
I think the short piggy-back cable that runs from near-side latch to off-side is at fault... I the lever feels ok from inside car then it's only releasing the near-side but off-side remains locked !!
yippee got the bugger open :) after managing to get the plastic cover off the back of the latch and getting to the lever on the back of the latch,she opened .what had happened is the cable had come out of the bracket that sits on the nipple on the back of the latch and also the bracket that holds the cable had come off the nipple
      Noise
      Noise
    3. 2
      Misfire at 2000rpm
      Bmw 116d 2011 her fault codes
      2010 X1 Water leak on passenger side footwell
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
    • welshchy earned a badge
