Bmw X5 Sunroof Help
Hello all, on the topic of the failure code 28 "oil thermal sensor oil level defect", considering this is an early vehicle that does not have an oil thermal sensor, and I do not have a fault on the dash, is the fault above an oil level fault and not an oil thermal sensor? I have read that if the oil level sensor fails the car will not start. is this true? Many thanks all for the great support!! Dimitri
