Fell In Love With A Porsche
3.0i starter motor
Bmw x1 2012 won't start
I recently had a problem with my bmw x1 2012, failed to start,fault code came up , got the foot control module and battery replacement, not even two days of driving the car won't start again and the engine light is on .mechanic is now saying it's the starter
