Sat in my bmw compact with the engine running, then noticed a burning smell and saw that me temperture was in the red.
Now i get some clicking noise coming from under the hood.
Has anybody had that problem?
Get that into a garage ASAP sounds like the head gasket has failed and is losing compression from the outside
The "clicking" may be the engine "Pinking" at overheat stage so deffo head/gasket issue... Did you let it run in an overheated state for long?
Pre-Ignition (in an overheating engine) is where the engine becomes hot enough to fire the fuel before the spark-plug !
As stated above, the ping sounds like pinking. Premature bang
You might get away with it NOT being a head gasket problem but you wont if you don't get it to a grease monkey as soon as possible.
Post back with your findings
      Newbie here
      Appears no fire
      Appears no fire
    5. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
