1St South East Meet.....15Th July 2012
Misfire at 2000rpm
Bmw 116d 2011 her fault codes
Hi Raymond Welcome to the Forum Sun Roof Drains are a known culprit doesnt take much fror them to get clogged Dave -
Misfire at 2000rpm
Hi John Welcome to the Forum I would check very carefully the loom to the coil packs and the Injectors. I have seen a misfire fault on a Volvo T5 and a BMW 335i neither car logged fault codes. Both cars would start and run smoothly and show no fault or misfire even when revs were raised, but if the car was under load the symptoms were there. The T5 it was injector harness with cracked insulation and the BMW failed insulation on the loom to the Coil Packs Hope this helps Dave -
I have a 2010 x1 which has developed a water leak, when I wash the vehicle with a hose pipe, there is water in the footwell on the passenger side. Any ideas and or help would be appreciated.
