3 Series E46
14
SLIPPING CLUTCH
SLIPPING CLUTCH
Hi Dave, I fitted one of the sensors on the rear but it has made no effect as the light is still there, I will fit the other sensor tomorrow and see how it goes then. You mention the disconnect the battery, is there any pattern to this ? is it both leads or just the negative lead? cheers Paneuro. -
Not sure what engine your running but there should be a Temp sensor in the Hose from the Rad to the water pump then there should be a Temp sensor in the housing for the Thermostat Both are shown in realoem for the 3.5 V8 I thought the V8 was the only one with dual use sensor on the Thermostat housing but stand to be corrected Dave
