Hi everyone I have just brought a 328 1999 now I don’t know if anyone can help me out here but it’s very bouncy on the road the bloke I got it off says he change the rear shockers to M-Tec, but I’ve had it on a ramp yesterday and there Yellow shockers ,
Now all I need really is may be a picture of standard shocks and springs or even part number as i want to replace these back to stock
hi there i had the yellows on my e36 328is there bilstien m3 shocks??? was lowered 20mm but was stiff as hell and rear end was lively!!! if your not keen best bet is ebay youl find plenty at good prices
Yeah thanks matey i had a look yesterday think i will change them back to standard
Put M-Tec shocks on it,they are standard BMW shocks but just better than 'standard' BMW ones :) I did :)
I have just replaced rear springs and shocks with mtec, no more bounce but ride very firm £156 quid with labour!! from my local garage
now that sounds good to me where did you get them from
Both came from a local factor, Pretty easy to fix yourself if you can get loan of a ramp, I note you are in Cheshire, Loads of factors in your county, better if you buy the bits as garages add at least 10% or more.Good luck
      Bmw 116d 2011 her fault codes
      Misfire at 2000rpm
      Noise
      Noise
    5. 3
      Misfire at 2000rpm
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
