There's a nosie coming from the engine that is not normal and it has no go at all any advice??
Coming from top of the engine and making a loud blowing noise sounds like the exhaust has blown but is coming from top of engine
You put your foot down you get nothing and it's very juddery when you go to pull from light
Defo sounds like a split hose,prob the big one behind the MAF sensor !! The Mrs has go a compact that had the same prob,sorted that pipe and sorted the problem !!
May just need a good service ! Could be an engine breathing issue (bunged up pipework)... Just a thought, hard to say without being there !!
Spray bottle of soapy water and a running but cold engine is what you need :)
Get back to us with your results
Daz
Turnsout it was the cat. It was blocked and was put the car in get me home mode
All done now yay got my BMW back on the road
Kieran
      3.0i starter motor
    4. 0
      Bmw x1 2012 won't start
    5. 6
      X3 2.0 automatic
    • BLM06 earned a badge
    • Marvin chui earned a badge
    • Davesally earned a badge
    • Backmarker earned a badge
    • Karlos70 earned a badge
