Hello Everyone...
Newbie here
Hi just wanted to introduce myself I have just retired and after years of company cars have bought my own car as a daily driver. I have ended up with a 320D coupe M Sport 2013 I am motor trade back ground although in the Truck business. I have a classic car Triumph TR6 and a Motorbike Street Triple 675 taking a bit of getting used to being responsible for my own car 😂 -
12
12
12
Hi I have a couple of problems with my 2009 x5 xdrive. 3.0d first of all. Should I be able to select neutral with the ignition on with engine but not started. Secondly, since I’ve been unable to select different gears or neutral I cannot get my car to start. I’ve changed fuel pump relay as not getting any fuel to fuel rail. Are used to be able to select a neutral with the engine off with this now stop the car starting
