Before upping the power via emaps, I think I need to address the standard braking system on my E61 535D. A few squeaky bum moments promps me to at least change the pads. Anyone got any experience of upgrading a 5 and if so what would you recommend? what do M5's run with?
Best thing to do is get cross drilled/grooved discs all round and better pads like Brembo,Green Stuff,Yellow Stuff etc. I did it to my 3 series and glad I did :) check ebay for the bits you need :)
With snypa all day long. Tackle the obvious bits before looking into 'upgrades'
ok guys, now then which ones? on ebay they range from 250 to 1200 quid, obviously dont wanna buy cheap and they end up goosed, dont wanna buy expensive to later find i could have got the same result for a lot less.. Whats the best combos with value for money. Bear in mnd, im not going racing , just want to significantly improve what is frankly a poor standard system.
Im thinking bog standard drilled grooved discs/greenstuff pads, or am I better spending on quality discs and ok pads??
help
good choice!! brembo are vgood ive had ebc turbo discs n red stuff pads (race rated) n wasnt upto scratch had brake fade plus discs warped!!
      520d advice
    2. 13
      Fuel rail pressure problems.
      Would you buy this car?
      Selling a BMW wall charger
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
    • Amk earned a badge
