Newbie
Electrical issue
Hi, I have a strange issue on my 2013 2.o diesel X1. It has been runniing fine for years until today when we tried to start it was dead. Tonight i jumped it straight away but now when you start it the lights are on all the time but the windows dash lights and other electrical functions do not work . Now I have run it round the block the battery which is only 6 months old it starts the engine no problem. Any ideas ? could it be an emergency get you home mode as the lights work -
Rear View mirror has come off windscreen screen
3m squares will seal it! does the car have a sensor on the glass? -
22
BMW 318i boot locked can’t get into
Hi, open the bonnet and use the charging points in there. Put the charger on and the boot should open using the fob. also, I have seen cars getting enough power from connecting an external battery/ car to the cigarette lighter, if you have one?- bmw
- bmw 3 series
(and 4 more)
Tagged with:
22
And, of course, if you can't open the hood, you can't use the + and - to put power to the doors, windows, lights, keyway, etc.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
22
I just now remembered that you could use under the hood cables to hook up to a good battery. That should allow you to open the boot and doors.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
