Hi Philip Welcome to the Forum If I recall the Power Steering Fluid was originally a Febi part not sure if it was the Green one to protct seals etc Try taking a look at www.realoem.com Classic section or even ask your Dealer Parts dept they do some good deals on older models Dave -
Morning Alan Welcome to the Forum Iwould think if the Dealer realises the DPF has been tampered with then they probably won't touch the car at all. Have you checked to see if your car still has it's EGR and Cooler I have read that they are often removed with the DPF work. When the EGR is replaced checked the Dealer will need to run diagnostics and I would think that will tell the tale. Also if the MOT station suspect a tampered DPF it is a fail. Be aware that if BMW replace the DPF it will be a costly excersize I would think in the region of £2k Dave -
