By
Ayrton,
in BMW 3 Series Forum
From E83 to F25
The spigot is the raised ring on the wheel hub that locates the wheel. It should match the big centre hole in the middle of the wheel, If the one in the wheel is smaller it wont fit if it's larger thewheel wont centre correctly and will probaly wobble Good Luck Buddy -
BMW climate control issues
Hi, Thank you Dave, yes it does help appreciate it, will check the fuses first of all, Gemma -
From E83 to F25
Thanks mate I will Deffs check that site out. Appreciate. God knows what a spigot is hahaha -
From E83 to F25
Hi Ian Welcome to the Forum Check www.realoem.com put the last 7 digits of your Vin into the search box (one car at a time) then check the wheels section. Check the wheel szes for both cars and the wheel Offset so you know they clear Brake Calipers The only other thing is check the spigot ring measure ment on both wheels Hope this Helps Dave -
From E83 to F25
My 2010 m sport E83 has a fuel pump issue and it looks like I need a new fuel pump in the engine and injectors and it’s not gonna be cost-effective to keep it. it’s dead on my drive, selling for spares and repairs I guess With that in mind I have bought an F25 but it’s on 17 inch wheels compared to the 19 on my other I was thinking about swapping the wheels over. Do you think that would work okay? I also need to pimp up this 2L SE what do you suggest I do? 🤩
