Iluminusbutterfly's E46 Build
Good advice from Greydog, but in the latter years I would pay for used parts, ordinary mixing coolant with drinking water, bought used tires, and new when I had to. Keeping up with old cars is a chore. One of these days I will pay $240 for a new HV/AC solenoid. Two 3/4" brass, Hollow L shaped, will do for now. I will also remove the inside of the thermostat moving parts (and keep the rest) in the old cars. My other cars are: '97 Volvo 850 GLT wagon, '95 Volvo 960 wagon, and the newest is a Mercedes 2003 CLK430.- bmw
- bmw 3 series
(and 4 more)
Hello Dave thanks for your reply, thanks for the reply and it does sound like that could be the problem. I was thinking injector but never pops an engine light up so wasn’t certain. Was serviced 6500 miles ago but was just oil and filters. Going to check later and see if I can see any visible cracks or splits. Got a friend who has a garage and will obd and smoke test it for me. Billy
