New Member
Rear View mirror has come off windscreen screen
3m squares will seal it! does the car have a sensor on the glass? -
22
BMW 318i boot locked can’t get into
Hi, open the bonnet and use the charging points in there. Put the charger on and the boot should open using the fob. also, I have seen cars getting enough power from connecting an external battery/ car to the cigarette lighter, if you have one?- bmw
- bmw 3 series
(and 4 more)
Tagged with:
22
And, of course, if you can't open the hood, you can't use the + and - to put power to the doors, windows, lights, keyway, etc.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
22
I just now remembered that you could use under the hood cables to hook up to a good battery. That should allow you to open the boot and doors.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
22
I probably won't be able to remember exactly step by step. (That happened with a 2003 Mercedes, one problem similar to the '92 BMW 325i. That time my battery looked like nearly new, but it was quite old. A new battery solved that problem.) As for the '92 , the instrument cluster lights likely went out some day before that day. It works, but lights are out. I have some extra lights; just haven't removed it yet. I have a few clusters that I have bought used over the years. Now the most important: The back driver's side door window was opened about one inch; I used a coat hanger to pull knob up; (the driver's door). After that it was easy. I put a new battery in and turned the ignition key; all was good. You might have to use a circular hole saw behind your car tag to open the boot.- bmw
- bmw 3 series
(and 4 more)
Tagged with:
