Newbie!! 330I Temp??
Morning Max You should have access to the Live terminal (Red Cap) the Neg terminal is on the inner wing (Large Nut) Information should be in your handbook Hope this helps Dave -
14
Good advice from Greydog, but in the latter years I would pay for used parts, ordinary mixing coolant with drinking water, bought used tires, and new when I had to. Keeping up with old cars is a chore. One of these days I will pay $240 for a new HV/AC solenoid. Two 3/4" brass, Hollow L shaped, will do for now. I will also remove the inside of the thermostat moving parts (and keep the rest) in the old cars. My other cars are: '97 Volvo 850 GLT wagon, '95 Volvo 960 wagon, and the newest is a Mercedes 2003 CLK430.- bmw
- bmw 3 series
(and 4 more)
Hello Dave, Just an update and I think you may be right. Went out and gave it a few revs when cold, nothing. Let it warm up and there was a loud “shoooo”. I’ve attached a photo of where the sound was coming from. Going to get it looked into but do you have any idea of what it could be? First BMW, always had vag cars so engine are a little different to what I’m used to
