Hi all, light has been on since iv owned the car was told loose wire under pas seat, on sat whilst havin a tinker i borrowed mateys diagnostics reader went thru the whole car and come up with drivers tensioner?? zk1 somthing to do with buckle or pretensioner?? anyone had the same code and sorted it? if so what am i lookin for? all wires are clipped in no loose ones, any help would be great cheers
hi i had same light on mine once , i disconnected the battery for half hour and that sorted mine out seems this has happened to a few people try that hope it helps you
      Bmw 116d 2011 her fault codes
    2. 4
      Misfire at 2000rpm
      Misfire at 2000rpm
      Noise
    • welshchy earned a badge
    • Michal earned a badge
    • JohnLC earned a badge
    • rjrive earned a badge
