Electric Window Problem
First thoughts were cam / crank sensors but unless the new ones are faulty then I would start looking at the fuel system. If the car has been stood for a while then I would firstly look at changing the fuel filter - rarely changed as its an expensive part and also tucked away under the sill. Also look at the battery connections and it may also have an SRS power cutout on the positive cable which may also be faulty but be careful testing this as it has an explosive charge -
Morning Gabriel Welcome to the Forum The smooth running test tells you more, if idle is smooth and raising revs and letting them fall back doesn't upset the smooth running test all should be OK. Injector values are easy to reset but to do it you need the numbers on the top of each injector and that will need access to the injectors. Personally if things are running well MPG and Performance where you would expect I would leave it and monitor it once a month or so Enjoy your Beemer Dave -
My friend has a 1997 Z3 which will run for a few miles then cuts out. Will start and run again then intermittently cuts out. He has had crank shaft cam shaft sensors changed. I know probably could be anything, but I thought that I would ask. -
My son is getting creative
…. And my wife just got a speeding ticket! I’m going to find a corner to cry in! -
Ironically, he used the drill bit I was looking for to attach the number plate to the new caravan…. I gave up trying to redecorate the other one him and his sister painted! 😂😫🙄🙄🙄
