318 Backbox + Airfilter
Morning Gabriel Welcome to the Forum The smooth running test tells you more, if idle is smooth and raising revs and letting them fall back doesn't upset the smooth running test all should be OK. Injector values are easy to reset but to do it you need the numbers on the top of each injector and that will need access to the injectors. Personally if things are running well MPG and Performance where you would expect I would leave it and monitor it once a month or so Enjoy your Beemer Dave -
My friend has a 1997 Z3 which will run for a few miles then cuts out. Will start and run again then intermittently cuts out. He has had crank shaft cam shaft sensors changed. I know probably could be anything, but I thought that I would ask. -
My son is getting creative
…. And my wife just got a speeding ticket! I’m going to find a corner to cry in! -
Ironically, he used the drill bit I was looking for to attach the number plate to the new caravan…. I gave up trying to redecorate the other one him and his sister painted! 😂😫🙄🙄🙄 -
… decided he wanted to draw a robot….. on the x5…. With a drill bit! needless to say, his mother is now talking to him upstairs very loudly! IMG_1980.mov- 1
