hi guys had the 7 series a few days now and have discovered a few little niggle bits
1 the pasenger window makes a scraping noise on its way down and needs help going back up
2 there are three seat belt straps in the back but only two belt sockets
3 the halo lights arnt that bright
any ideas would be helpfull
Hi Chris, is the window in the guides ok, have you checked in the back of the seats for the 3rd socket, the lights, could the lights ned replacing or bad connections, good luck Chris, hope you get it sorted out.
hi Al i not messed about with the window to much yet
had a right good look under seat for third socket its nowhere to be found
and i lifted the bonnet to have a look at the lights and there is so many covers in the way i cant get to the lights to investigate all you get at under there is the oil filler and rad expantion tank
Hello chris i have the oppisite to the seat belt prob< i Have 3 sockets and only the 2 outside belts but i have found the other (lap belt) way behind the centre arm rest and gonna somehow have to try and dig out might be the same with your socket, is this an E38?
    • SteveC51 earned a badge
    • Dan_C earned a badge
