audio problem with my 2003 m3 individual
6
My son is getting creative
Update! … bonnet and boot sourced and awaiting delivery from a very nice guy who breaks BMWs… Tim at bmw classic spares in Northampton. once they are on, I’ll set about polishing the whole car and try to hide the side scratches. It’ll be like a new un! -
9
Bmw angel eyes
Hi Ben Without carrying out a full test on each TMS it is difficult to say. I would check the internet for any test criteria then start with the good one note the results then test the faulty one to compare. All I found on the TIS is it is likely to be the LED's (2 of them) how simple it is to change them I have no idea. As an Example I recently had a failed Halo/Parking lamp on my E70 checked ISTA says remove cover 3 screws remove 2 further screws and the lamp is out Ha Ha Ha. What i discovered in WIS was a note that says remove Headlamp from the car to access the screws. Dave
