Im having loads of trouble starting when its cold. Its been fine in the summer but this problem started last winter and now its come back. It appears that the engine is flooding when i attempt to start it (took the plugs out and they are soaking with petrol) when it does start it runs terribly untill it warms up and then its fine, starts ok when its warm. Had the fault codes read and it came up as the crank sensor + temp sensor faulty. Changed both of them but im still having trouble starting. Had the ecu tested and came back, no faults detected. Any ideas fellas?
