320D Blown Turbo Help Please
Hi there little help please my 2000 reg e49 320d
has been diagnosed with a blown turbo but car won't start
at all is this correct sorry to sound thick but all of the petrol
turbo cars I have owned with blown turbo the car has still started
but smoked is it right for a diesel to not run at all when code
turbo gone. Cheers in advance
Hey
The car SHOULD start with a blown turbo but if it has blown to a point where it is no longer allowing exhaust gases to escape, it will build so much back pressure that the exhaust valves will struggle to open therefore, no start.
Also, if the turbo has blown, it might of taken something else with it that the ECU relies on to start.
These are only theories brought to my head by logic.
When you say "won't start", what exactly do you mean? Does it even turn over? is it dead? does it start then die?
Daz
It turns over perfect just won't fire won't even cough or try but has a strong turn over ok
Hmmmm
Unless this is some annoying BMW electrical system that won't allow the car to start now it has detected a problem (which I don't know about) I'm stumped. You can drive a car forever on a blown turbo if you don't mind the horrific fuel consumption, a cape like black smoke trail behind you and a top speed of 50.
I've even known people to kill the oil feed from the block to the turbo to stop the most of the nasty black smoke jsut to continue driving on a blown turbo lol but never it not starting.
I'm sorry to advise but it doesn't sound like your turbo dude. If it is your turbo, it knackering its self has taken something else out with it causing the ECU to lock down.
Your going to have to go back to basics and check for Spark, Fuel and Air to the cylinders...
Daz
squirt some brake cleaner up the inlet manifold, see if it fires
It could just need a good kick in the rear like Ian suggests :rolleyes: Let us know how this goes
