Has anybody had a problem with smoke from the exhust on start up when the engine is cold, it lasts for about 20 seconds
A common issue with all diesels, due to the colder seasons the cold engine will not burn the fuel efficiently enough hence the pale smoke leaving the exhaust, the 20 secs is enough to warm the mixture !
Worse case scenario would be worn valve-guides, but the smoke would smell of engine oil as opposed to raw diesel ;)
Sounds about right. The cold weather really does effect motors
Daz
Diesels will smoke more on start up if the glow plugs are down. A very common fault code on BMW but very rarely causes a starting issue as on other makes. A fault code scan would tell you this,
Yeah that does sound about right, I've noticed that I get it sometimes on my diesel when I attempt to overtake too
if it starts a little rough in mornings could be glow plugs. INPA will show up as 'Glow device'
But as said above, whiteish smoke is normal. Worn valve guides would be blue ish smoke and a distinct smells. Same for rotten turbo (plus you would smoke the whole street out)
      Tyres for front of my 240i
      520d advice
    4. 13
      Fuel rail pressure problems.
    5. 2
    • delh1982 earned a badge
    • Norberg earned a badge
    • gabrielbrr earned a badge
    • Tony J01 earned a badge
