Replacement E30 Grey Leather Seats
Hi. I’m literally in the same situation. Did you manage to get it fixed? If so, how? -
2008/09 520d
2009520d The radio wont store presets / stations Any ideas? Regards Martin. -
drivetrain check soon msg
840 d 2018 My cluster had blown after and resulting in a battery drain. Managed to source a second hand one which was fitted and lasted 30 mins. Once blown battery drained again and an intermittent 3 second beep in the car when driving. Removed the fuse for the cluster to stop the beeping and the battery stopped draining . Concluding the blown cluster is causing the battery drain but cannot find the cause of cluster blowing.
