Hi as stated above I have all the problems which all occured at once on a very cold and snowy day. I was wondering if you guys had any idea what my problem could be with my 2003 330ci? Running perfect but warning lights everywhere! Thanks Dean
I had a similar issue with warning lights, speedometer and fuel consumption not working and it turned out to be a faulty speed sensor on my passenger side rear wheel. Once it was replaced solved all the problems
Reset the codes on OBD as Gav says, the fuses too inc. under-bonnet relays etc...
Seems like an electrical issue obviously but did you experience any interior condensation??
  • 11 months later...
Hi, did anyone find a solution for this problem? Ive suffered this faulty recently! Ive cleared the codes but they come back intermittently!
Guest Mr.Beemer
I am assuming the speed sensor contacts are on the dirty side -
also go through the fuses making sure there sitting in properly.
first thing to do is to pull the codes through the obd port
    5. 13
    • JCDenton earned a badge
    • Luke330 earned a badge
    • Ken C earned a badge
