Newbie Saying Hi
Hi My rear suspension failed last week and I diagnosed the problem to the a 'sticky' main solenoid ( not the two way block) I replaced the solenoid and checked it and the compressor before re- fitting to the car. Guess what/ The compressor doesn't work as there is s no 12v to the compressor The fuses (152 and 182) are fine and the relay works when tested 'on the bench'? Any ideas guys? -
No emergency door lock
Afternoon Frankolinno Welcome to the Forum I would start at the Boot/Trunk look above the number plate for a Key hole, you should have a key blade as part of the Fob Find the Key hole open the Boot/Trunk and you have access to the Battery. If charging the battery remove it from the car to charge it. There should also be an emergency key hole on the underside of the drivers door Good Luck Dave -
Hi my Battery is flat, my fob does not work. Removed caps at the side of the door handles, no emergency keyholes/locks present. I do have the fob keys, but no lock to put them in. BMW 420d 2014 Any ideas how to get in the car? Any help appreciated Thank you -
Morning Alexander Welcome to the Forum Paul used Liquid Moly additive I beleive, do remember that if the seals are hardening through age this will work if the seals have gone it can't do much Dave -
Bmw x4 2015 angel eyes
Morning Ben Welcome to the Forum Never actually seen this but from what I read it is normally the Halo LED's failing and needing replacement Dave
