took battery off e46 318i saloon 1998 to charge it up forgot about boot and closed it now cant get in to put battery back as i dont have a key for boot as it came form scarpyard with out i no what a idot please help :mellow:
There is a battery point under the bonnet on the drivers side, look for a plastic cap with a + sign on
it, if you have jump leads the rest is straight forward.
thanks i was thinking of doning that but dont no if it will work with no battery been on?
There is only one way to find out !
job done put booster pack on battery point under bonnet first turn of key boot opened
get in there job well done at no cost. :D
Where do i send the bill :lol:
    2. 6
    3. 14
    4. 13
      SLIPPING CLUTCH
    5. 13
      SLIPPING CLUTCH
    • Karlos70 earned a badge
    • DDONNY earned a badge
    • Dimitris earned a badge
      Collaborator
    • DAW90 earned a badge
    • jn1253 earned a badge
