735I
Bmw 116d 2011 her fault codes
Hi Chynna Welcome to the Forum What Diagnostic Reader did you use although many readers will give a code they will be general rather than specific A BMW capable Diagnostic reader will normally not just give a code it will also give a description of the fault helping in diagnosing a fault Dave -
2010 X1 Water leak on passenger side footwell
Hi Raymond Welcome to the Forum Sun Roof Drains are a known culprit doesnt take much fror them to get clogged Dave -
Misfire at 2000rpm
Hi John Welcome to the Forum I would check very carefully the loom to the coil packs and the Injectors. I have seen a misfire fault on a Volvo T5 and a BMW 335i neither car logged fault codes. Both cars would start and run smoothly and show no fault or misfire even when revs were raised, but if the car was under load the symptoms were there. The T5 it was injector harness with cracked insulation and the BMW failed insulation on the loom to the Coil Packs Hope this helps Dave -
I have a 2010 x1 which has developed a water leak, when I wash the vehicle with a hose pipe, there is water in the footwell on the passenger side. Any ideas and or help would be appreciated. -
My name 116d has a judder when accelerating, strong smell from exhaust and low mpg I plugged a diagnostic reader in and it came up with EGR codes, I have replaced my EGR valve, map sensor mafs sensor and breather hose but still experiencing the same issues plugged in reader again still says egr codes and then bank 1 lambda sensor so replaced that and still have the egr codes. any one have any idea what it could be as have sunk loads of money into it so far and don't want to keep doing so
