Hello chaps, A wee question for you , hopefully you can help, My 330d 51 reg, has an intermittent rattle at dront of engine, driver side sounds as if its right behind the headlight, any ideas? its a tinkling rattle , not a tap tap , cheers in advance dudes tam
Is there some heat protector loose mate?
it sounds like somethin like that, i,ll get a look soon, cheers
my rattle sounds like its right behind driver side headlight,, its not the engine , engine seems solid, plus its intermittent, does sound like somethings loose like you said, i havent had a chance to have a good look yet, but thats first tyhing i,ll look for mate
Keep us posted mate
Keep us posted mate
turned out its the air con belt tensioner, i,m goin to remove belt for now , yass
      Z3 airbag wiring,
      Z3 airbag wiring,
      Bmw x1 2012 won't start
    • JayMe earned a badge
    • Andrewkuk earned a badge
    • DAW90 earned a badge
    • Max123 earned a badge
