Strange Rattling When Dropping Revs Untill 3K
Morning Billy You need a diagnostic session to narrow things down, at 161k I would also carry out a compression test and check fuel delivery and pressure. Your symptoms could be an accumulation of things or as simple as a dying throttle body diagnostics will help Dave
