Hi
Bought a bmw 635 csi that had been stood for 2 months it is MOT'd for 10 months. Put a new battery on her, drained old fuel and put fresh in but it will not start. Has great spark on all 6 plugs l, pump working as should, fuel on all 6, dried plugs and put oil in pots to create compression but it will not start.
Any ideas will be greatly received
Cheers
Tim
If all you have said is true then it will be a sensor(s) at fault.
Does it even "try" to start or just turn over? Does the Starter Motor spin well or does it seem tired?
Try unplugging and re-plugging all wiring connectors under the bonnet, maybe spray with WD40...
Concentrate on the Crank PS, Camshaft PS and Throttle PS, these three sensors are the babies that run the bugger via ECU !
Another thing to check is Fuel Pressure and its regulator, on the fuel rail(s) there should be, what looks like, a tyre-valve... press the needle in to expel air !
Just a couple of thoughts for you matey ;)
Cheers
It's just turns over with no attempt to start. I did think the sensors might be an issue.
Bit strange ..
Thanks again :)
Like above, check the 3 sensors Dabsy mentioned first mate.
There are way to test them without getting new ones, but google it as I dont want the blame if you short something out.
Good luck
  • 2 years later...
My 635 has been running slightly lumpy, then just stopped whilst ticking over...now just spins over and will not fire .....put 3 gallons of fresh fuel ...but just spins ...any ideas please...
      Series 1 review mirror has detached from my windscreen
      1997 Z-3 2.8 14,000 original miles for sale
    3. 2
      Replaced key battery still can't unlock car
      Cost of service 420i
    • Sturmobile earned a badge
    • Kropac1 earned a badge
    • Billinz50 earned a badge
    • 4seriesinessex earned a badge
