Hi All just taken over the reigns of my Mums z3 2.8 on a 98 reg
shes not serviced her for a while and I can tell. The roof leaks etc but I can handle that myself however
Battery dies 12 hrs after charging - alternator?
No heating unless its at a standstill - ????
Engine temperature never leaves cold
mayo under filler cap -
It all points me to the headgasket but I have read other people saying the thermostat being stuck open would cause all these issues :/
any ideas?
Thermostat stuck open would only cause the engine to run cold and not cause the beige mulch !
This mulch will have been caused by either a failed head-gasket or cracked head.
Maybe in the past, this thermostat was stuck closed causing these faults then releasing after time with its spring ??!!
Either way matey, I think the head has to come off eventually !!
Short-term fixes are - New stat and water-pump plus a small bottle of K-Seal... If only to buy some time before you sort the head-gasket ;)
As above mate...
But just a question, has it been standing a long time and now only doing very short journeys?
Thats just clasping at straws and hoping the HG hasn't gave up...I rekon Dabsy is right though.
Its been stood a month but just done Birmingham to Leeds then ive had a good look at her
Get the head off mate, get it tested.
I'd park her up too as you could be causing more damage driving her around..
Bad news I know, I've had a HG go on a BMW recently..
Cheers gents... Nightmare only got her to run around in for a few months whilst the missus sells her Polo
      Newbie here
      Appears no fire
      Appears no fire
    5. 12
    • Larry36 earned a badge
    • Graham J earned a badge
    • Sogra earned a badge
    • Aaronelvis earned a badge
