hello, I have just bought a 2005 bmw x5 with auxiliary heating (webasto) fitted. I can select timer 1 and timer 2 in the display on the computer but I cannot access direct mode.does this mean that the heater has not been activated,as I understand that bmw did not activate these heaters in the ecu as standard for uk cars. when I set the timers, the blowers work ok but there is no heat,which makes me think that either the heater is not working or it has not been enabled,any advice would be gratefully accepted.thank you in advance.
      Alloy wheels
