Hi
Last post i stated that car would not start. This was due to poor compression, so we filled the pots with oil over and over and 18 spark plugs later if started.
The car now is a ##### to restart and back fires trying. Ticks over well enough but when you switch it off it is hard to start and again back fires.
Any ideas?
Thanks
Tim
E92 M3
E24 635 CSI
Crank sensor, Throttle Position sensor or Cam sensor... One or more of those matey ;)
As stated above, those need checking first. What car is it? The E24 6 series?
Daz
Well spotted Daz... If it is pre-92 then it may not have one or more of these sensors. If that is the case then it will most deffo be physical engine/ignition timing.
Shouldn't need to worry to much about the top/bottom end timing as if my memory serves me correctly, the M30 is chain-driven. Have a good look at the distributor...
Some Polish clown with a sackful of Pizza-Leaflets :lol:
HAHAHAHAHAHAHA Ow, thats good Dabz :D
  • 1 year later...
Had same problem with my 1984 635csi
Turned out to be ecu giving wrong signals to airflow meter.
Sent unit to BBA REMAN and had it repaired
That was after changing a whole load of parts
      Newbie here
    2. 4
    3. 13
      Newbie here
      Appears no fire
    • nickl81809 earned a badge
    • Mark lingham earned a badge
    • Benny Brown earned a badge
    • Paul M earned a badge
    • Drumj earned a badge
