At the risk of getting stoned to death could do with some help with I EMPHASIZE MY PARTNERS vauxhall verctra b 2.0 DTI.....
can anyone come up with suggestions apart from a galllon of petrol and a match lol....
engine management light keeps coming on its been scanned it was showing a EGR fault .... so it has had replaced;
EGR valve .......didnt work
Map sensor ....still the same
Mass air flow .....ditto
air mass .....3 times
all pipework checked no blockages and pipes holding pressure....
Codes have been reset each time ......
at a total loss now ......He needs to sort this out to sell it and buy a proper car any help plllllzzzzzzz
As a EGR is a mechanical part the fault will obviously be coming from a sensor.
EGRs can be blanked off/not needed, and been as you have had it changed it eliminates that issue.
Not sure what sensors are on or around the erg but will look into it for you..
Are there any performance issues?
Lambda sensor?
Is IT running ok?
I was thinking Lambda sensor too...
Again...any running issues?
It surges on the revs sometimes .......When ive driven it i reckon it takes a while to pick up when you pull away .....
the error code is PO400 ..........
when the code is cleared it flies and then the engine management light comes on and it goes into limp mode.....
when you open it up its fine and flies tbf
It was originally saying insufficient flow now saying excessive flow
Like a "Flat-spot"?
MAF sensor is not shaking-hands with the fuel-pressure ! (In laymans terms - like having the wrong jets in a carburettor) ....
This is the physical issue you have but, the sensors are what are giving the ECU/DME the confusion.
Excess carbon deposits can cause your issue too ;)
      Alloy wheels
    • Gouden earned a badge
    • Markc earned a badge
