Hi Guys
I have a 1989 635CSI that will not hold charge..
I have replaced the battery and altenator but when i drive lights start to go dim then when i stop it wont start as no charge.
Any ideas/common faults?
Thanks
Tim
First job (easiest) is to check and tighten ALL the earth-leads/straps... Often this will cure it.
Next job, run the engine and test the voltages with a meter (anywhere theres a positive), test on a few different locations to eliminate broken connections.
Finally, if no solution so far, check relays and regulator for operation/connections... Go back to second job !
Just a simple method HTH
Super cheers
Strap a earth lead from alternator to body and it is now fixed
Thanks for your help :)
      Series 1 review mirror has detached from my windscreen
      1997 Z-3 2.8 14,000 original miles for sale
    3. 2
      Replaced key battery still can't unlock car
      Cost of service 420i
    • Sturmobile earned a badge
    • Kropac1 earned a badge
    • Billinz50 earned a badge
    • 4seriesinessex earned a badge
