Hi Everyone
Electrical issue
Morning Gary Welcome to the Forum Even a relativley new battery can die fully charge the battery (make sure you use the charge points under the bonnet) measure the voltage engine off key out at the charge points it should read 12.5 to 12.8v below 12v is either dying battery or a dead short somewhere. Once battery is at full charge engine running measure again you shouls see 14.8v indicating a healthy alternator. Engine off key out let the car go to sleep (takes up to 10 mins) then measure amperage at the under bonnet charge points you should se a few milliamps (clock, memory items etc) if your seeing higher you have a paracitic drain which will need tracking down. Check the starter motor a failing one can kill a battery really fast Hope this helps Dave -
Rear View mirror has come off windscreen screen
Morning Paul I believe you can also get an adhesive to stick it back, goes without saying the screen and disc have to be really clean and dry Dave -
Electrical issue
Hi, I have a strange issue on my 2013 2.o diesel X1. It has been runniing fine for years until today when we tried to start it was dead. Tonight i jumped it straight away but now when you start it the lights are on all the time but the windows dash lights and other electrical functions do not work . Now I have run it round the block the battery which is only 6 months old it starts the engine no problem. Any ideas ? could it be an emergency get you home mode as the lights work -
3m squares will seal it! does the car have a sensor on the glass? -
22
BMW 318i boot locked can’t get into
Hi, open the bonnet and use the charging points in there. Put the charger on and the boot should open using the fob. also, I have seen cars getting enough power from connecting an external battery/ car to the cigarette lighter, if you have one?- bmw
- bmw 3 series
(and 4 more)
Tagged with:
