World Record Attempt
Front shocks
420i STAGE 1?
Morning Billy Welcome to the Forum When upgrading performance I have always increased the frequency of Oil Filter changes just to make sure everything stays in tip top condition As long as your not driving it at the max every second then I think you should enjoy your Beemer Dave -
Morning Jim Welcome to the Forum Try Disconecting the Battery for 20/30mins (Dealer Trick) to see if it resets then. If not you could have a faulty wheel sensor a Diagnostic check will tell you Dave -
Front shocks
Hi all, Can anyone please direct me to the front shocks I need? Appreciate the help Kieran -
420i STAGE 1?
I am wondering if it is worth it to get a stage 1 tune on a bmw 420 2019 f32 model, I have heard it makes them a lot more responsive and fun to drive but also that the 20i engines aren’t exactly built strong enough to be pushed that far as the stage 1 brings it to around 250bhp I believe. Do you think it’s worth it or is there any way you can strengthen the engine for the tune?
